JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis • Text Explorer
Text
Explorer
Explore Unstructured Text in Your Data
Many features in this platform are available only in JMP Pro and noted with this icon.
The Text Explorer platform enables you to analyze unstructured text, such as comment fields in surveys or incident reports. Interact with the text data by using tools to combine similar terms, recode misspecified terms, and understand the underlying patterns in your textual data.
The JMP Pro version of the platform also contains analysis tools that use singular value decomposition (SVD) to group similar documents into topics. You can cluster text documents or cluster terms that are in a collection of documents. You can also cluster documents using latent class analysis.
Figure 11.140
SVD Plots in Text Explorer
Contents
Overview of the Text Explorer Platform
Text Processing Steps
Example of the Text Explorer Platform
Launch the Text Explorer Platform
Customize Regex in the Regular Expression Editor
The Text Explorer Report
Summary Counts Report
Term and Phrase Lists
Text Explorer Platform Options
Text Preparation Options
Text Analysis Options
Save Options
Report Options
Latent Class Analysis
Latent Semantic Analysis (SVD)
SVD Report
SVD Report Options
Topic Analysis
Topic Analysis Report
Topic Analysis Report Options
Discriminant Analysis
Discriminant Analysis Report
Discriminant Analysis Report Options
Additional Example of the Text Explorer Platform
Help created on 10/11/2018
