The Response Screening report consists of several Graph Builder plots. These plots focus on False Discovery Rate (FDR) statistics. For details, see The False Discovery Rate.
The default plots are the FDR PValue Plot, the FDR LogWorth by Effect Size, and the FDR LogWorth by RSquare. If you select the Robust option on the launch window, Robust versions of each of these reports are also presented. In addition, a Robust LogWorth by LogWorth plot is presented to help assess the impact of using the robust fit. The standard Graph Builder red triangle options for each plot are available. For details, see Red Triangle Options in the Essential Graphing book.
