/* specify two table scripts. */
%LET _DS_ATTRIBUTES=_JMP_TABLESCRIPTCOUNT=2
/* define the table script names */
_JMP_TABLESCRIPTNAME_1="Favorite Movie By State"
_JMP_TABLESCRIPTNAME_2="OnOpen"
_JMP_TABLESCRIPTVALUE_2="CurrentDataTable() << RunScript(""Favorite Movie By State"");"
/* define the OnOpen table script */
_JMP_TABLESCRIPTVALUE_1=
/* a portion of the OnOpen table script */
	Current Data Table();
	New Column(""max_name"",
		Character,
		Width(128)
The following example shows how to combine PROC DATASETS with extended attributes:
%LET _DS_ATTRIBUTES = attr-name=attr-value...attr-name=attr-value;
%LET _VAR_ATTRIBUTES= var-name (attr-name=attr-value...)...var-name (attr-name=attr-value...);
PROC DATASETS NOLIST LIB=WORK;
  MODIFY AttributeReferenceTable;
  XATTR OPTIONS MAXCHUNK=100;
  XATTR SET DS &_DS_ATTRIBUTES;
  XATTR SET VAR &_VAR_ATTRIBUTES;
RUN;
QUIT;
See Conventions for Mapping JMP Attributes to SAS Extended Attributes for details about SAS extended attributes and their corresponding JMP attributes.
Two SAS Integration preferences determine whether extended attributes are imported or exported. Select On export, store table and column properties in extended attributes to export extended attributes. Select On import, apply table and column properties from extended attributes. The options are deselected by default.
sd = dt << Make SAS Data Step Window( SaveJMPMetadata( 1 ) );
Help created on 10/11/2018
