JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Fitting Linear Models •
Stepwise Regression Models
• Using Validation
Using Validation
In JMP, you can perform cross validation by selecting the
K-Fold Crossvalidation
option from the Stepwise Fit red triangle menu. See
K-Fold Cross Validation
In JMP Pro, you can specify a Validation column in the Fit Model window. A validation column must have a numeric data type and should contain at least two distinct values.
If the column contains two values, the smaller value defines the training set and the larger value defines the validation set.
If the column contains three values, the values define the training, validation, and test sets in order of increasing size.
If the column contains four or more distinct values and the response is continuous, these values define folds for k-fold validation.
For more information about using a Validation column, see
Validation Set with Two or Three Values
Help created on 10/11/2018
