JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Fitting Linear Models • Stepwise Regression Models
Find a Model Using Variable Selection
Stepwise regression is an approach to selecting a subset of effects for a regression model. It can be useful in the following situations:
There is little theory to guide the selection of terms for a model.
You want to interactively explore which predictors seem to provide a good fit.
You want to improve a model’s prediction performance by reducing the variance caused by estimating unnecessary terms.
For categorical predictors, you can do the following:
Choose from among various rules to determine how associated terms enter the model.
Enforce effect heredity.
The Stepwise platform also enables you to explore all possible models and to conduct model averaging.
Contents
Overview of Stepwise Regression
Example Using Stepwise Regression
The Stepwise Report
Stepwise Platform Options
Stepwise Regression Control Panel
Current Estimates Report
Step History Report
Models with Crossed, Interaction, or Polynomial Terms
Example of the Combine Rule
Models with Nominal and Ordinal Effects
Construction of Hierarchical Terms
Example of a Model with a Nominal Term
Example of the Restrict Rule for Hierarchical Terms
Performing Binary and Ordinal Logistic Stepwise Regression
Example Using Logistic Stepwise Regression
The All Possible Models Option
Example Using the All Possible Models Option
The Model Averaging Option
Example Using the Model Averaging Option
Using Validation
Validation Set with Two or Three Values
K-Fold Cross Validation
Help created on 10/11/2018
