Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
JMP Reports
Change the Appearance of Graphs
• Add a Graph to a Data Table
JMP.com/help
You can add a graph to a new data table. Right-click on a graph and select
Edit > Make table of graphs like this
. The graph and the variables appear in a new data table.
Tip:
To make the graph larger, resize the table cell.
Figure 9.34
Histogram and Y Variable Added to Data Table
Help created on 3/19/2020
