Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
JMP Reports
• Change the Appearance of Graphs
JMP.com/help
There are many ways that you can format your report to meet your needs. The sections that follow detail how to make changes to the graphical portions of your output reports.
Tip:
If you have a touchscreen, you can pan and zoom most graphs and axes in JMP. Graphs and axes change scale and zoom out if pinched, and zoom in if stretched.
Resize Graphs
Zoom In and Out
Display Images on Hover Labels
Pin Hover Labels on a Graph
Change Line Widths
Change the Background Color in a Graph
Change the Color of Histogram Bars
Display Coordinates and Temporary Reference Lines
Scroll and Scale Axes
Customize Axes and Axis Labels in the Axis Settings Window
Customize Axes and Axis Labels Using the Pop-Up Menu
Change the Order of Values
Change the Pattern and Format of Selected Objects
Add a Graph to a Data Table
Customize Graphical Elements
Help created on 3/19/2020
