Select Help > Sample Data Library and open Design Experiment/Reactor 8 Runs.jmp.
Select DOE > Augment Design.
Select Percent Reacted and click Y, Response.
Select Feed Rate, Catalyst, Stir Rate, Temperature, and Concentration and click X, Factor.
Figure 6.12 Choose an Augmentation Type
6.
Select Group new runs into separate block to add a blocking variable to the design.
7.
Click Replicate, enter 2, and then click OK.
Figure 6.13 Reactor Data Design Augmented with a Replicate
8.
Click Make Table.
Figure 6.14 The Replicated Design
Help created on 3/19/2020
