Note: For details about the Multivariate platform, see Correlations and Multivariate Techniques in the Multivariate Methods book.
Select Analyze > Multivariate Methods > Multivariate.
The density ellipses in the Scatterplot Matrix further illustrates relationships between variables. Figure .8 shows a portion of the plot.
Select Pairwise Correlations from the Multivariate red triangle menu to display the Pairwise Correlations report.
To quickly see which pairs are highly correlated, right-click in the report and select the Sort by Column, Signif Prob, Ascending check box, and then click OK.
The most highly correlated pairs appear at the top of the report. The small p-values for the pairs indicate evidence of correlation. The most significant correlation is between Tot Carbo (total carbohydrates) and Calories.
