Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
• Correlations and Multivariate Techniques
JMP.com/help
Explore the Multidimensional Behavior of Variables
Use the Multivariate platform to explore how many variables relate to each other. The word multivariate simply means involving many variables instead of one (univariate) or two (bivariate). From the Multivariate report, you can do the following:
summarize the strength of the linear relationships between each pair of response variables using the Correlations table
identify dependencies, outliers, and clusters using the Scatterplot Matrix
use other techniques to examine multiple variables, such as partial, inverse, and pairwise correlations, covariance matrices, principal components, and more
Figure 3.1
Example of a Multivariate Report
Contents
Launch the Multivariate Platform
The Multivariate Report
Multivariate Platform Options
Nonparametric Correlations
Scatterplot Matrix
Outlier Analysis
Item Reliability
Impute Missing Data
Example of Item Reliability
Computations and Statistical Details
Estimation Methods
Pearson Product-Moment Correlation
Nonparametric Measures of Association
Inverse Correlation Matrix
Distance Measures
Cronbach’s
α
Help created on 3/19/2020
