Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Measurement Systems Analysis
Measurement Systems Analysis Platform Options
• Average Chart
JMP.com/help
Average Chart
The red triangle menu next to Average Chart contains the following options:
Show Grand Mean
Draws the overall mean of the
Y
variable on the chart.
Show Connected Means
Draws lines connecting all of the average measurement values.
Show Control Limits
Draws lines representing the Upper Control Limit (UCL) and the Lower Control Limit (LCL) and defines those values.
Show Control Limits Shading
Adds shading between the UCL and LCL.
Show Separators
Draws vertical lines to delineate between the
X
variables.
Show Data
Adds the data points to the chart.
Note:
You can replace variables in the Average Chart in one of two ways: swap existing variables by dragging and dropping a variable from one axis to the other axis; or, click on a variable in the Columns panel of the associated data table and drag it onto an axis.
Help created on 3/19/2020
