Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
JMP Reports
Use Markers
• Change Marker Size
JMP.com/help
Change Marker Size
To increase or decrease the size of markers on a graph:
Right-click anywhere in a graph. Hold down the Ctrl key and right-click to broadcast the command and apply it to all plots of the same type located in the same window. In a histogram, right-click the box plot area on the right.
Select
Marker Size
Select one of the marker sizes listed.
The default value, Preferred Size, is selected on the Graphs page in the JMP preferences.
Note:
When the drawing speed is set to Fast, the smallest marker size (Dot) is applied. See
Work with Crowded Markers
Help created on 3/19/2020
