Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
JMP Reports
• Use Markers
JMP.com/help
Use Markers
Markers are points on a graph that represent data. Once they are changed from their default setting, they also appear next to rows in the data table.
Change Marker Shape
Change Marker Colors
Change Marker Size
Work with Crowded Markers
Add Outlines Around Markers
Marker Selection Modes
Specify Marker Transparency
Exclude and Hide Markers
Add Labels to Markers
Use Images as Markers
Change Marker Shape or Colors Based On Values
Help created on 3/19/2020
