In the initial Compare Distributions report, the probability and time axes are linear. But suppose that you want to see distribution estimates on a Fréchet scale.1
Select Interval Type > Pointwise from the red triangle menu.
Figure 3.14 Nonparametric Estimates with a Fréchet Probability Scale
Select SEV in the Scale column.
The nonparametric estimates no longer approximate a straight line (Figure 3.15). You now know that the SEV distribution is not appropriate.
Figure 3.15 Nonparametric Estimates with a SEV Probability Scale
1
Help created on 3/19/2020
