Select Help > Sample Data Library and open Reliability/Blenders.jmp.
Select Analyze > Reliability and Survival > Life Distribution.
Select Time Cycles and click Y, Time to Event.
Select Causes and click Failure Cause.
Select Censor and click Censor.
6.
Select Individual Best as the Distribution.
7.
Make sure that AICc is the Comparison Criterion.
8.
Figure 3.11 Initial Competing Cause Report
Figure 3.12 Estimated Failure Time for 10% of the Units
10.
Select Omit for bearing seal, belt, container throw, cord short, and engine fan (the causes with the fewest failures).
Figure 3.13 Updated Failure Time
Help created on 3/19/2020
