This example shows how to compare a definitive screening with a Plackett-Burman design using the Evaluate Design platform. For an extensive example using the Compare Designs platform, see Designs of Same Run Size in Compare Designs.
Select DOE > Definitive Screening > Definitive Screening Design.
Click Continue.
Next to Number of Extra Runs, select 0.
6.
Click Make Design.
7.
Open the Design Evaluation > Color Map On Correlations outline.
Select DOE > Classical > Screening Design.
Click Continue.
Click Continue.
8.
Figure 7.15 shows both color maps, but shows only the portion of the Plackett-Burman color map that involves main effects and two-way interactions. (To construct the color map for the Plackett-Burman design without the three-way interactions, construct the design. Then obtain the color map using Evaluate Design.)
