Select Help > Sample Data, click Open the Sample Scripts Directory, and select Compare Same Run Size.jsl.
Right-click in the script window and select Run Script.
In the Plackett-Burman data table, select DOE > Design Diagnostics > Compare Designs.
7.
Click OK.
In terms of power, prediction variance, and estimation efficiency, the PB design outperforms the DSD. Figure 16.3 shows the Power Analysis report with the default settings for the significance level, Anticipated RMSE, and coefficients. For tests for the main effects, the PB design has higher power than does the DSD.
The Color Map on Correlations plots in Figure 16.5 show that the PB design aliases main effects with two-way interactions. In contrast, the DSD does not alias main effects with two-way interactions.
In the Model outline, select Interactions > 2nd.
