Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Essential Graphing
• Contour Plots
JMP.com/help
Contour Plots
View Multidimensional Relationships in Two Dimensions
The
Contour Plot
command in the
Graph
menu constructs contours of a response in a rectangular coordinate system. A contour plot shows a three-dimensional surface in two dimensions. Contours delineate changes in the third dimension.
Here are some of the options available with the Contour platform:
specify the number of contour levels
choose to plot contour lines or filled contours
show or hide data points
label contours with response values
define and use a custom coloring scheme
Figure 7.1
Examples of Contour Plots
Contents
Example of a Contour Plot
Example Using the Contour Platform
Example of a Contour Plot in Graph Builder
Launch the Contour Plot Platform
The Contour Plot
Contour Plot Platform Options
Fill Areas
Contour Specification
Contour Plot Save Options
Use Formulas for Specifying Contours
Additional Example of Contour Plots
Help created on 3/19/2020
