Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Correlations and Multivariate Techniques
Multivariate Platform Options
• Impute Missing Data
JMP.com/help
Impute Missing Data
To impute missing data, select
Impute Missing Data
from the red triangle menu for Multivariate. A new data table is created. This data table is a duplicate of your data table and replaces all missing values with estimated values.
Imputed values are expectations conditional on the nonmissing values for each row. The mean and covariance matrix, which is estimated by the method chosen in the launch window, is used for the imputation calculation. All multivariate tests and options are then available for the imputed data set.
This option is available only if your data table contains missing values.
Help created on 3/19/2020
