Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
• Extend JMP
JMP.com/help
Extend JMP
Create Dashboards
JMP is an extensible program that lets you broaden its functionality to create your own JMP components. With Dashboard Builder, you combine reports into a dashboard, a visual tool that lets you run and present reports on a regular basis. No JSL knowledge is required. Start with a template, click report components, insert graphs and pictures, and the dashboard is done. You can also combine windows outside Dashboard Builder to create dashboards.
Figure 11.1
A Dashboard with Two Reports
Contents
Combine Reports by Creating a Dashboard
Example of Creating a Dashboard with Two Reports
Details about Using the Dashboard Builder
Dashboard Builder Red Triangle Options
Sample Dashboards
Edit a Dashboard
View a Running Dashboard
Example of Combining Windows to Create a Dashboard
Example of Adding Selection Filters to a Dashboard
Example of Creating a JMP Query Dashboard and Add-In
Example of Creating a Dashboard from Two Data Tables
Help created on 3/19/2020
