Select Tables > JMP Query Builder.
Click Build Query.
In the Available Columns list, double-click t1.Movie Name, t1.Rotten Tomatoes Score, t1.Audience Score, and t1.Theaters Opening Wknd to add them to the Included Columns tab.
Click Run Query.
The queried data appears in a new data table. Note the Source table script. When you open the dashboard, JMP runs this Source script to query the data in Hollywood Movies.jmp.
6.
In the new data table, run the Graph Builder: Scores by Opening Weekend table script to create a report.
From the report window, select File > New > Dashboard.
Select the Blank Dashboard template.
Double-click the Data Filter(Local) box in the left pane to add it to the dashboard.
Figure 11.15 Dashboard for Hollywood Movies
From the Dashboard Builder red triangle menu, select Save Script > To Add-In.
Click the Menu Items tab and type Hollywood Movies Dashboard next to Menu item name (the name of the add-in menu item).
Click Save and save the add-in to your desktop.
Click Close on the Add-In Builder window.
6.
The Hollywood Movies.jmp data table is queried, and the dashboard opens to show the local data filter and updated report.
Figure 11.16 Hollywood Movies Add-In
