To extend the divider line to the x-axis labels, follow these steps:
Select Tick Marks > Divider Lines to add the lines, or Lower Frame to add a frame around the axis area.
Right-click a numeric axis and select Add Axis Label.
To remove an axis label, right-click a numeric axis and select Remove Axis Label. The last label added is removed.
Select Rotate Text.
Tip: To set a default axis label position for a variable, which avoids making this change every time you run an analysis, see Properties That Control the Display of Columns in The Column Info Window.
On a nominal axis, you can rotate tick marks. Right-click the tick label and select Rotated Tick Labels.
Select Edit > Copy Frame Contents.
Select Edit > Paste Frame Contents.
Tip: If you are having difficulty pasting histogram bars, see the JSL workaround in Copy and Paste Histograms in the Scripting Guide.
After customizing an axis (as described in Customize Axes and Axis Labels in the Axis Settings Window), you can copy and paste your new settings to another axis:
Select Edit > Copy Axis Settings.
Select Edit > Paste Axis Settings.
Tip: To broadcast the axis settings to multiple graphs, hold down the Ctrl key when you right-click the axis and select Edit > Paste Axis Settings.
