Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
• Degradation
JMP.com/help
Degradation
Model Product Deterioration over Time
Using the Degradation platform, you can analyze degradation data to predict pseudo failure times. These pseudo failure times can then be analyzed by other reliability platforms to estimate failure distributions.
Both linear and nonlinear degradation paths can be modeled. You can specify an accelerating factor to analyze accelerated degradation data.
You can also perform stability analysis, which is useful when setting pharmaceutical product expiration dates.
Figure 7.1
Degradation Analysis Example
Contents
Overview of the Degradation Platform
Example of the Degradation Platform
Launch the Degradation Platform
The Degradation Reports
Model Specification
Simple Linear Path
Nonlinear Path
Inverse Prediction
Prediction Graph
Degradation Platform Options
Model Reports
Model Lists
Reports
Destructive Degradation
Stability Analysis
Help created on 3/19/2020
