Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Degradation
Model Reports
• Reports
JMP.com/help
Reports
The Reports outline node gives details about each model fit. The report includes a Model Summary report, and an Estimate report.
The Model Summary report contains the following information:
<Y, Response> Scale
Transformation on the response variable.
<Time> Scale
Transformation on the time variable.
SSE
Error sums-of-squares.
Nparm
Number of parameters estimated for the model.
DF
Error degrees of freedom.
RSquare
Gives the r-square.
MSE
Mean square error.
The Estimate report contains the following information:
Parameter
Name of the parameter.
Estimate
Estimate of the parameter.
Std Error
Standard error of the parameter estimate.
t Ratio
t statistic for the parameter, computed as the Estimate divided by the Std Error.
Prob>|t|
p
-value for a two-sided test for the parameter.
Help created on 3/19/2020
