Select Help > Sample Data, click Open the Sample Scripts Directory, and select Compare Three Run Sizes.jsl.
Right-click in the script window and select Run Script.
You want to compare these three designs. Notice that the 16-Run Design table is active.
Click OK.
Figure 16.8 Power Analysis Comparison
Figure 16.9 Fraction of Design Space Comparison
Figure 16.10 Color Map on Correlations Comparison
Figure 16.11 Absolute Correlations Comparison
Figure 16.12 Design Diagnostics Comparison
7.
8.
In the Model outline, select Interactions > 2nd.
9.
Click OK.
The other two effects, X1*X3 and X2*X3, are added to the Compare Design report. You can examine the report to compare the designs if the two interactions are active.
