Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Basic Analysis
Bivariate Analysis
Fitting Menus
• Diagnostics Plots
JMP.com/help
Diagnostics Plots
The
Plot Residuals
option creates residual plots and other plots to diagnose the model fit. The following plots are available:
Residual by Predicted Plot
is a plot of the residuals versus the predicted values. A histogram of the residuals is also created.
Actual by Predicted Plot
is a plot of the actual values versus the predicted values.
Residual by Row Plot
is a plot of the residual values versus the row number.
Residual by X Plot
is a plot of the residual values versus the X variable.
Residual Normal Quantile Plot
is a Normal quantile plot of the residuals.
Help created on 3/19/2020
