This example uses the Cars.jmp sample data table, which contains impact measurements of crash-test dummies in automobile safety tests. Compare these measurements for different automobile makes and models during the years 1990 and 1991.
Filter the data to show only the years 1990 and 1991 and create a subset of the Cars.jmp data table.
Select Rows > Data Filter.
Select Year.
Click Add.
6.
In the data table, select Tables > Subset.
7.
Select Graph > Legacy > Treemap.
L Leg represents a measurement of injuries resulting from the deceleration speed of the left leg, where more deceleration causes more injury.
Click OK.
Figure 11.19 Left Leg Deceleration Injuries
From Figure 11.19, you can see that the Club Wagon and S10 Pickup 4x4 have the largest number of left leg deceleration injuries.
From the red triangle menu, select Change Color Column.
Select Head IC.
Click OK.
Figure 11.20 Head Injuries
From Figure 11.20, you notice the following:
