Select Help > Sample Data Library and open Body Fat.jmp.
Select Graph > Graph Builder.
Select Abdomen circumference and drag it to the Y zone.
Select Thigh circumference and drag it to the X zone.
6.
Select Weight (lbs) and drag it to the Color zone.
Figure 4.4 Contour Plot with a Color Variable
The contour colors correspond to the weight, as shown in the Weight (lbs) legend. The graph shows that thigh and abdomen circumference are related; as one increases, so does the other. The colored contours indicate how weight fits in the relationship. Individuals with large measurements of abdomen and thigh circumference are also generally the heaviest. Notice that one individual (row 32) does not quite fit the pattern.
Help created on 3/19/2020
