Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Essential Graphing
• Graph Builder Examples
JMP.com/help
Visualize Data Interactively
Graph Builder provides you with a variety of flexible ways to explore your data. This chapter shows examples of examining data using contour plots, bar charts, histograms, area plots, treemaps, and other types of plots.
Figure 4.1
Example Using a Formula, Bars, and a Reference Line
Contents
Example of a Contour Plot
Example of a Contour Plot with a Color Variable
Example of a Violin Plot
Example of a Stacked Bar Chart
Example of Custom Error Bars
Examples of Area Plots
Show Behavior over Time
Show Bounds around Group Means
Example of Overlaying Histograms with Transparency
Example of Wafer Maps Based on a Cluster Analysis
Example Using a Heatmap to Apply Background Colors
Example of a Treemap
Example of a Mosaic Plot
Example Using Images as Markers
Help created on 3/19/2020
