Note: These data are artificial, but inspired from an experiment reported in Box, Hunter, and Hunter (1978).
In the Tables panel at top left, click the green triangle next to Full Factorial Model.
Figure 4.13 Effect Summary Report
In the Effect Summary report, notice that the popcorn*batch interaction has a small p-value (0.00261). From this, you conclude that there is a significant interaction between popcorn and batch.
This saves a column that contains the prediction formula to the data table. The new column is Pred Formula yield.
Select Graph > Graph Builder.
6.
7.
8.
9.
Figure 4.14 Yield Values for the Eight Factor Combinations
10.
Format the graph to see interval bars for Lower 95% Mean yield and Upper 95% Mean yield, and to see points for Pred Formula yield.
12.
The interval bar style currently spans from Lower 95% Mean yield to Pred Formula yield, but you want it to span up to Upper 95% Mean yield. Remove the bar element for Pred Formula yield.
13.
Figure 4.17 Interval Span for Confidence Boundaries
14.
In the Points options under Variables, deselect Y Lower 95% Mean yield and Y Upper 95% Mean yield. See Figure 4.17.
15.
16.
(Optional) Click Done.
Figure 4.18 Predicted Means and Confidence Intervals
From Figure 4.18, you can see the following relationships:
