Complete Example Using the Fit Curve Platform in Fit Curve to fit the model. This example shows how to save the prediction formula from Fit Curve and then set parameter limits in Nonlinear.
From the Logistic 4P red triangle menu, select Save Formulas > Save Parametric Prediction Formula.
A new column named Toxicity Predictor appears in the data table.
Select Analyze > Specialized Modeling > Nonlinear.
Assign Toxicity to the Y, Response role.
Assign Toxicity Predictor to the X, Predictor Formula role.
Assign Formulation to the Group role.
6.
The Nonlinear Fit window appears (Figure 13.17). In the Control Panel, parameter values and locking options are shown. The letters listed before each parameter correspond to variables from the Prediction Model in the Fit Curve function.
Figure 13.17 Nonlinear Fit Control Panel
7.
Select the red triangle menu next to Nonlinear Fit and then select Parameter Bounds.
8.
Set the lower bounds for the parameters as shown in Figure 13.18. You know from prior experience that the maximum toxicity of the drug is at least 1.1.
Figure 13.18 Setting Parameter Bounds
9.
The final parameter estimates are shown in the Solution report, along with other fit statistics (Figure 13.19). The fitted model is shown on the plot.
Figure 13.19 Nonlinear Fit Plot and Parameter Estimates
Help created on 3/19/2020
