Select Help > Sample Data Library and open Blood Pressure.jmp.
Each BP (blood pressure) column is delineated according to the date and time. The BP 8M column corresponds to readings that were taken at 8am on Monday. The BP 12W column corresponds to readings that were taken on 12pm on Wednesday, and so on. The researcher wants to stack all of the blood pressure columns into three columns that correspond to each day: Monday, Wednesday, and Friday.
Select Tables > Stack.
Select Multiple series stack.
7.
Rename the Stacked Data Column from Data to BP (for blood pressure).
Figure 6.10 Completed Stack Window
9.
Figure 6.11 Stacked Data Table
The first Day column represents Monday.
The Day 2 column represents Wednesday.
The Day 3 column represents Friday.
Help created on 3/19/2020
