You can create a new data table from the active table by splitting one column into several new columns. This column is split according to the values found in another column, referred to as the Split By column. You can also split columns according to the values of one or more grouping variables.
Select Tables > Split.
Figure 6.12 Split Window
Click Split By.
6.
Click Split.
