Select Help > Sample Data Library and open Big Class.jmp.
Select Analyze > Fit Y by X.
Select height and click Y, Response.
Select sex and click X, Factor.
From the red triangle menu, select all three options: Densities > Compare Densities, Densities > Composition of Densities, and Densities > Proportion of Densities.
Figure 6.36 Example of the Densities Options
Help created on 3/19/2020
