You have data containing height measurements for male and female students. You want to create a table that shows the sum of the heights by the age of the students. Then you want to stratify your data by sex in different tables. To do so, add the stratification column as a page column, which will build the pages for each group. You want the table to look like Figure 9.23.
Select Analyze > Tabulate.
Since height is the variable you are examining, you want it to appear at the top of the table.
Click height and drag it into the Drop zone for columns.
Click age and drag it into the blank cell next to the number 2502.
6.
8.
Select M from the Page Column list to show the mean of the heights for only males. You can also select None Selected to show all values.
