Select Tables > Transpose.
Click OK.
The original table in Figure 6.16 has two rows and three continuous columns called plastic, tin, and gold. The transposed table has a row for each of the three columns in the original table, and columns named Row 1 and Row 2 for the original table’s rows. The additional column called Label has the column names (plastic, tin, and gold) from the original table as values.
Click OK.
The values from the item column in the original table are used as column labels in the transposed table.
Click OK.
