Select Analyze > Reliability and Survival > Life Distribution.
Click OK.
Select Fit Mixture from the red triangle menu next to Life Distribution.
6.
7.
Select Separable Clusters in the Starting Value Methods panel.
8.
Click Go.
9.
10.
Click Go.
From the Lognormal(1), Weibull(1) red triangle menu, select Save Predictions.
Select Analyze > Distribution.
Check Histograms Only.
Click OK.
6.
In the histogram for Lognormal(1), Weibull(1) - Predicted Probability from Weibull, click in the bar corresponding to the value near 1.
