You have no failures (all observations are right-censored) and the preference Weibayes Only for Zero Failure Data is checked. Then the Weibayes report appears. See Weibayes Example for Data with No Failures.
Select Likelihood as the Confidence Interval Method.
7.
Click OK.
8.
Type 1.5 as the known Weibull β value.
9.
Click Update.
7.
Click OK.
8.
Select the Weibull distribution in the Compare Distributions plot.
9.
Select Fix Parameter from the Parametric Estimate - Weibull red triangle menu.
10.
11.
12.
Click Update.
14.
Place your cursor over the top of the Y axis. The cursor becomes a hand. Drag the axis downward until it reaches 0.5 as the top number.
