Specifies the fitting methodology. See Fit Model Launch Window Elements. Different options appear depending on the personality that you select.
(Available only in certain personalities and when Y is binary and has a nominal modeling type.) Specifies the level whose probability you want to model.
Frequency variables, entered in the Freq text box, are supported in most Fit Model personalities. In general, a frequency is interpreted as follows. Suppose that a row has a frequency f. Then the computed results are identical to those for a data table containing f copies of that row, each having a frequency of one.
When estimation is performed using least squares or normal theory maximum likelihood, the weight w for a given row scales that row’s contribution to the loss function by w-1/2.
Help created on 3/19/2020
