Figure 9.7 The Tabulate Interactive Table
(Only appears if Show Chart is selected from the red triangle menu.) Enables you to specify a uniform custom scale.
(Only appears if Show Chart is selected from the red triangle menu.) Deselect this box for each column of bars to use the scale determined separately from the data in each displayed column.
Help created on 3/19/2020
