Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Nonlinear Designs
• Nonlinear Design Window
JMP.com/help
The Nonlinear Design window updates as you work through the design steps. The outlines, separated by buttons that update the outlines, follow the flow in
Figure 23.16
Figure 23.16
Nonlinear Design Flow
The initial design window shows the Factors, Parameters, and Design Generation outlines.
Figure 23.17
Initial Design Window
Help created on 3/19/2020
