Performs a Bayesian bootstrap analysis. In each bootstrap iteration, each observation is assigned a weight that is calculated as described in Calculation of Fractional Weights in Basic Analysis. The weighted observations are used in computing the statistics of interest. By default, the fractional weights option is not selected and a simple bootstrap analysis is conducted.
Numeric Formats in the Using JMP book describes the arguments. Note that Matrix Box(), Number Col Box(), Number Col Edit Box(), Number Edit Box() have the same Set Format syntax.
<<Set Format( 10, 2, "Use thousands separator");
<<Set Format( "Currency", "EUR", 20, );
<<Set Format( "m/d/y", 10 );
<<Set Format( "Precision", 10, 2, "Keep trailing zeroes", "Keep all whole digits" );
<<Set Format( "Latitude DDD", "PUNDIR"); // "PUN" for punctuation, "DIR" for direction, PUNDIR for both
<<Set Format( "Custom", Formula( Abs( value ) ), 15 );
For a list of currency codes, see Currency in the Scripting Guide. The currency code is based on the locale if the code is omitted.
Options can be defined in a list or a variable, or they can be in a Function() that is evaluated.
ncbFunc = Function({}, {"Fixed", 12, 5});
