The Print Algebraic Reliability to the Log Window command prints the reliability formula for the selected system diagram to the Log window.
(Windows only) Select View > Log.
(Macintosh only) Select Window > Log.
Open the exampleRBDcomplete.jsl file that you created.
In the Designs panel, select Computer.
From the Computer red triangle menu select Print Algebraic Reliability to the Log Window.
Figure 11.29 Algebraic Reliability in Log Window
