Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Control Chart Builder
Control Chart Builder Options
• Right-Click Axis Options
JMP.com/help
Remove
Removes a variable.
Remove Graph
Removes the entire graph.
For details about the Axis Settings, Revert Axis, Add or Remove Axis Label, and Edit options, see
Customize Axes and Axis Labels in the Axis Settings Window
and
Customize Axes and Axis Labels Using the Pop-Up Menu
in the
Using JMP
book.
Help created on 3/19/2020
