After you enter your responses and factors and click Continue, you can make selections for your design table in the Output Options outline. The structure of the full factorial design appears at the top of the outline.
Figure 12.10 Output Options Panel
The Run Order options determine the order of the runs in the design table. Choices include the following:
Help created on 3/19/2020
