Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Basic Analysis
Simulate
The Simulate Results Table
• Simulated Power Report
JMP.com/help
Alpha
The significance level: 0.01, 0.05, 0.10, and 0.20.
Rejection Count
The number of simulations where the test rejects at the corresponding significance level.
Rejection Rate
The proportion of simulations where the test rejects at the corresponding significance level.
Lower 95% and Upper 95%
Lower and upper limits for a 95% confidence interval for the simulated rejection rate. The interval is computed using the Wilson score method. See Wilson (
1927
Tip:
Increase the Number of Samples for a narrower confidence interval.
Help created on 3/19/2020
