As you run a script, the output appears in the log window. The actual script is shaded in the log, and the output appears beneath it (Figure 4.8).
Syntax and compatibility errors are reported in the log, including the line number and code that JMP could not process (Figure 4.9).
On Windows, you can control when the log opens: when JMP starts, when text is written to the log, or only when you open it. Select File > Preferences > Windows Specific to change the Open the JMP Log window setting.
To omit compatibility warnings from the log, deselect Show log warnings for JSL compatibility changes in 12 in the JMP General preferences.
