Select Tables > Summary.
Click OK.
From the red triangle menu in the upper left corner of the data table grid, select Add Statistics Column.
6.
Select the column that you want, click Statistics, and select the specific statistic that you want. For this example, select profit/emp and click Statistics, and then select Mean.
7.
Click OK.
