Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis
Contingency Analysis
• Analysis of Means for Proportions
Note:
For a description of Analysis of Means methods, see the document by Nelson et al. (
2005
). See also
Example of Analysis of Means for Proportions
If the response has two levels, you can use this option to compare response proportions for the X levels to the overall response proportion. This method uses the normal approximation to the binomial. Therefore, if the sample sizes are too small, a warning appears in the results.
The following options appear in the red triangle menu:
Set Alpha Level
Selects the alpha level used in the analysis.
Show Summary Report
Produces a report that shows the response proportions with decision limits for each level of the X variable. The report indicates whether a limit has been exceeded.
Switch Response Level for Proportion
Changes the response category used in the analysis.
Display Options
Shows or hides the decision limits, decision limit shading, center line, and point options.
Help created on 7/12/2018
