Select an option from the most common alpha levels or specify any level with the Other selection. Changing the alpha level modifies the upper and lower decision limits.
(Only for ANOM for Variances) Changes the scale of the y-axis from standard deviations to variances.
Show Decision Limits shows or hides decision limit lines.
Show Decision Limit Shading shows or hides decision limit shading.
Show Center Line shows or hides the center line statistic.
Point Options: Show Needles shows the needles. This is the default option. Show Connected Points shows a line connecting the means for each group. Show Only Points shows only the points representing the means for each group.
